Thread: Mirror position
    May 2011
    Mirror position
    I've purchased a set of left & right mirrors from Rare Spares to fit to my HJ ute & they don't have any fitting instructions. I found several threads referring to GTS mirrors, but I haven't found measurements for the correct position of the std mirrors. I fitted a left one to a HZ wagon I had in 1988 but can't locate the instructions that I kept.
    FD 206 Page 2
    Max has a copy maybe he can share the information required.
    Selling HJ 253 Engine
    Max has kindly supplied a copy of the fitting instructions.
    Follow these and you should be good.
    In metric should be (but please check):
    26.924 mm Down at front
    21.336 mm Down at rear
    21.336 mm In from edge
    67.564 mm Between holes
    6.5278 mm Hole (drill)
    May 2011
    Thanks for that, much appreciated.
