Results 1 to 9 of 9
Thread: Confused. Help please on possible Sandman ID
    Aug 2017
    Perth WA
    Hi guys,
    New to the forum, and have very confusing Tags that lead me to believe the vehicle I have is possible a genuine Sandman.
    Any help to clarify would be greatly appreciated.
    The vehicle is a HJ utility
    Tag says:
    HJ Coupe Utility
    4-75 BHJ 04937 M
    CVW 2155kg Seating Cap 3
    Model: HJ8WM80
    LD1 M15 CV7
    Originally I was told the ute had column shift, and a 6 cyl as the tag probably states. But it says seating Capacity 3 even though it looks like it came from the factory with bucket seats?? I inherited it with bucket seats and the middle console metal plate looks to be welded in from the factory, but I'm not 100%.
    Thanks if anyone can correctly ID this as an original Sandman ute or not.
    Cheers,
    Adam
    Don't thing it's a Sandman. 3 speed and 3 seater can't be. As for the console mounts, they can be added or the tags don't match the body.
    Not a Sandman
    3 seater noooo wayyy
    Could have been re bodied but tags are not sandman
    Aug 2017
    Perth WA
    Thanks guys,
    Nevermind... With the
    BHJ 04937 M
    and the
    HJ8WM80 model
    I thought it could be.
    It even has absynth yellow as the original factory color!
    Quote Originally Posted by HJUTE1975 View Post
    Thanks guys,
    BHJ 04937 M
    and the
    HJ8WM80 model
    The numbers give it up as a "Holden" Ute made at the "Melbourne" plant.
    Yes, Absynth is a HJ colour. Nothing Sandman from the tags about it though!
    It's a 6cyl with the 3 on the tree running a GV7 = 3.55:1 diff ratio.
    HJUTE1975, I would add, even if you are a bit disappointed on the assessment that its probably not Sandman, you still have an HJ ute!
    Clean it, shine it, use it, etc. I reckon theres a good chance it's value could surprise you in years to come. It's worth considering that a Sandman costs money to get it right and keep it up to premium. A standard ute requires heaps less money, and its useful. Cheap parts, and potentially, it can go on forever. There are few comparable vehicles. Sandman or not, I don't think there are many in Australia theres days who would say an HJ ute is not a classic car.
    Aug 2017
    Perth WA
    Thanks, you are absolutely right. Cheers
