Results 1 to 8 of 8
Thread: Battery for 308 Electronic Ignition
    Leadfoot DNO62's Avatar
    Jun 2016
    North of Port Douglas
    Hello folks,
    Just chasing a recommendation for a Battery for my 308 with electronic ignition.
    What cranking amps and recommended brand would be greatly appreciated.
    Cheers,
    I have used Delkor for 10 years never had any problem with them get 5 years out of them
    you would want at least 450 to 500 cca
    I run 700cca in ours
    Stay away from the calcium type,our old charging systems are not made for them.
    Old fashioned wet type will do
    Also have to say into the 7th year on ours.
    LEDs for lighting in the back and the interior fans are usb.
    Also always have the powerall jump pac with us as well(just in case)the larger version easy starts her up.
    Cheers Kiwivan
    Quote Originally Posted by Valencia View Post
    no chance bro. 550 plus for an old stinky V8. I had a 620 that had trouble with a tired 253
    The biggest you can fit in the battery carrier
    You need thicker cables thats what i do with the old stinky V8s
    Jun 2016
    Thanks guys for your advice, it would appear the bigger the better.
    Size does count.
    Quote Originally Posted by DNO62 View Post
    Size does count.
    But you got to know how to use it
