Results 1 to 5 of 5
Thread: Gear box
    Gear box
    Guys wanting some help here
    Have noticed when in first gear the gear-lever is that sloppy I can pull it over towards third.
    I take it this is a linkage problem
    And this is in a 1978 HX.
    Gearbox is a M 21
    Any help will be much appreciated before I start solving this problem.
    Cheers Kiwivan
    It is common in a car with a worn shifter or out of adjustment but if it has slowly got worse it is wear the shifter will need a rebuild or replacing
    Thanks for that
    Gearbox changes nice and smooth
    And that is through the full range up or down
    Will have a look at the linkages first
    Cheers Kiwivan
    Yep... Linkages or bushes in the shifter.
    Ta guys
    Cheers kiwivan
    For some strange reason I seem to have collected another avatar?
