Results 1 to 6 of 6
Thread: Red Motor Vs Blue Motor Factory Air Cleaner
    May 2012
    Sorry guys if this has been covered off before. I searched the forums and could not see it anywhere.
    Can I fit a 4bbl quaddie blue motor air cleaner to my HZ red 308 motor that is running a 4bbl quaddie of a blue 253? I have converted the carb to run an electric choke due to the elderbrock performer manifold and wanting to keep a choke for the chilly winter mornings! I plan to still run both PCV/breather hoses.
    Thanks
    I see no reason why not.....
    May 2012
    Thanks Big Rob. For reference, this is the air cleaner that I would like to use:
    breather (front) from RH rocker goes to carby on WB i think it goes to cleaner on HZ.
    LH rocker (rear) on WB goes to cleaner and on HZ goes to carby.
    I'm sure you can make it work though
    I wanted my engine bay to look like HZ so with red rocker cover I welded up the breather hole in the rear of the air cleaner and cut a new one in the front to go to the front left had side rocker cover . I used a 4 barrell rothchester carby
    AC and chock all worked fine
    HZ jasmine yellow sandman van
    HX mandarin red sandman ute
    Married to Jennie285
    May 2012
    Thanks Rodney. Did you use a 4bbl of a HZ or later blue motor?
