Results 1 to 7 of 7
Thread: Body removal
    P Plater matt.p's Avatar
    Wollongong NSW
    Body removal
    Hi guys
    I have hit a little bit of a hurdle removing the body from my chassis. I have a problem with the front outter bolts. I had cleaned up all the dirt and soaked the tops of the bolts with rust off however when loosening these bolts in particular i have torn the locating tabs and the threaded plate now rotates hence i cannot undo the bolts.
    I have tried holding the plate with multi grips and it does stop it from rotating but the bolts seem to be seized.
    Any ideas please
    Bit if heat maybe
    of ..
    Try cutting straight through the rubber mount and bolt with a recip saw or grinder. This would enable separation of the chassis from body which will then enable the remaining bolt sections to be removed easier.
    Can you get in there to cut the bolt heads?
    Can you get a angle grinder or die grinder in and cut the head off the bolt? Tack weld the plate back on? Can you put a picture up??
    Damien's idea would defiantly work. separate it then worry about it later. New bolts should be available from Rares. I sent them samples a few years back from memory.
    Wollongong NSW
    I tried to get a grinder in there but the little 4 inch doesnt quite reach. I have cut the rubber away and i think i will try and use the dye grinder. Something that i didnt even think of. Thanks guys
