Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Rochester carb, and engine model by numbers?
    Leadfoot Spike's Avatar
    Oct 2014
    Hoping someone can identify the carb fitted to my 308, it has the following numbers on it
    17084695
    0234JHT
    I want to make sure I get the correct service kit for it
    ALSO It sits atop an engine with the following # O [poss Q] T 441080. the block is blue but has been repainted. is it a red, blue or black motor
    thanks in advance
    QT is red motor.
    Oct 2014
    Thanks wbute, that would make sense as it is in an HX, cheers
    QT is a HQ 308.
    QT is 308/5.0LT HQ thru HZ except for the very last of the HZ's which were ZT prefix.
    This ZT prefix was used after the QT numbering clocked over 100000.
    As others have said QT is 308 in the HQ range of models and later variants. But I would say by your engine number that it is earlier than HX, more like originally released in an actual HQ ie 1973ish. On the block between the timing case cover and passenger side head will be a date code, that will answer the question of the blocks origins. It contains numbers and a letter eg 25G4.
    I don't recognise the carby number, but it looks like a GMH one. If it is it will be later VK. However I thought I had all GMH quadrajets already identified.
    Oct 2014
    OK guys I have 77K3 date code on the engine......
    Can't be 77
    Likely 11
  1. 465 holley carb
    By HJRAY in forum Engine
    Last Post: 14-06-2013, 12:26 AM
  2. Replies: 2
    Last Post: 05-06-2013, 08:12 PM
  3. Approximate engine numbers by month build
    By adam perth in forum Engine
    Last Post: 09-07-2010, 09:51 AM
  4. Wanted Carb, 465 Holley, Qjet, or Edelbrock 500
    By bribiegreen in forum Archive
    Last Post: 19-06-2010, 04:39 PM
