Results 1 to 9 of 9
Thread: Hj van Forbes nsw
    Hj van Forbes nsw
    A guy rang my last night and want me to confirm weather he had a sandman or not
    Iam fairly sure it is essecially because of the tyre placard
    2200 kgs gvm is high but I think this is correct for HJ 75 build
    Please confirm that iam correct to say this is a sandman and hk another set of tag for you
    Body I'd plate
    Model HJ8WM70
    Body 150548A
    Trim 1898 60V
    L31 M21 GV4
    VI Plate
    8M70TEL3 09089 J
    Comp plate
    07-75
    BHJ 22428 A
    2200kgs
    2seats
    Tyre placard
    9930173 ND
    Has GTS dash,full length hood lining ,fluted guards
    double head light front end which has obviously been change from the original single head light front
    And has no rust is in very good condition body wise apparently
    Thank you RB
    HZ jasmine yellow sandman van
    HX mandarin red sandman ute
    Married to Jennie285
    Flamenco_not_Flamingo
    Guest
    Hi Rod, just asking, but um.... is he selling it?
    Tyre placard has no relevance at that time Rod, it is the same placard for all V8 HJ commercials. There is nothing there to say it isn't, only the console brackets will tell you.
    It should be 5/75 too not 7/75. All the numbers align with 5/75. Chassis number is slightly off what i'd expect (i'd expect it to be maybe BHJ223xx or BHJ222xx) but this isn't that unusual for Elizabeth at this time.
    Quote Originally Posted by Flamenco_not_Flamingo View Post
    He has just purchased it
    Would these brackets held its identification
    Quote Originally Posted by RodneyHZ253 View Post
    Yep, that front mount is the same designed one as I found in my ute. That is the "early" type front console mount I was referring to a couple of months back when I mentioned (wrongly, as I was under the impression it was a HJ specific part) about its design. Doesn't have slots or notches in it. Looks pretty original too.
    I think you are right 5/75 I my of got that wrong I will check with owner later
    [QUOTE=RodneyHZ253;87283]I think you are right 5/75 I my of got that wrong I will check with owner later
    Deauville blue, same as my HJ except mine has black interior and is full of tinworm.
  1. Cheap WB Kingswood body and rails in Forbes
    Last Post: 11-05-2012, 07:55 AM
  2. Forbes Show n Shine
    By jennie285 in forum The Lounge
    Last Post: 11-10-2011, 04:02 PM
