Results 11 to 12 of 12
Thread: Vs ute - fuel smell in cabin
    Flamenco_not_Flamingo
    Guest
    This was a common issue in ALL VN-VS Commodores, but more so with utes, because the cavity where the tank is located is close to the passenger compartment. With sedans & wagons any vapours from minor leaks are vented externally.
    The fix is to remove the ute floor (Philips screws), remove the fuel tank & replace all the vapour hoses with quality fuel resistant neoprene hose. Go to a Pirtek or Enzed outlet & spend a few $$ on thin wall low pressure hydraulic hose, it's worth it.
    The factory hoses have 2 faults, the small rubber ones just rot away & fall apart, while the larger vapour hose to the filler neck turns rock hard & won't seal at its ends. You will find that the tank will have been leaking petrol (liquid & vapour) for years, from every joint.
    It's not rocket science & anyone can do it with a bit of patience & common sense.
    Dr Terry
    Or sell it lol
    Quote Originally Posted by Flamenco_not_Flamingo View Post
    Or sell it lol
    ive lost count of how many VS utes i've sold over the years because i couldn't figure it out. one had only done 90,000 and stunk. another had done 240,000 with no smell. totally wrecked my brain. so glad to have a definitive answer. thanks very much!!!!!!!!!!!!!!!!!!
    i pulled the cover off this arvo and found the canister vapor return line was rotten in half. I plugged it with a bolt and it made no difference to smell. Probably just puts more pressure on the other leaking areas. what a drama
  1. Replies: 6
    Last Post: 28-03-2013, 03:09 PM
  2. Cabin Rear(Ute)
    By SandmanMuscle in forum Paint & Panel
    Last Post: 29-04-2012, 07:44 PM
  3. Replies: 1
    Last Post: 09-09-2011, 10:06 AM
  4. Cabin Back Wall Panel
    By GNW1974 in forum HQ Sandman
    Last Post: 20-07-2011, 07:20 AM
  5. HJ Van fuel cap
    By GTS in forum Archive
    Last Post: 12-04-2011, 04:53 PM
