Results 1 to 3 of 3
Thread: Original setting for rear springs
    Cruiser Wombat7051's Avatar
    Oct 2013
    Caloundra, QLD
    I hope someone can help me, I took the HZ springs in today to be reset to original. I need to find out the original camber of the springs. This is the distance between a straight line draw between the eyes down to the bolt in the centre of the spring. Thanks
    I have the following:
    HZ ute/van standard springs, part numbers 9935933 & 35 (LH & RH):
    Primary x 3 @ 8mm, secondary x 1 @ 13mm.
    Primary RH: 3270nM @ 66mm camber.
    Secondary RH: 6565nM @ 13mm camber.
    Primary LH: 2800nM @ 66mm camber.
    Secondary LH: 6065mm @ 13mm camber.
    Primary rate is 29.3 kN/m
    Secondary rate is 51.8 kN/m.
    This is straight from the HZ features manual.
    Oct 2013
    Caloundra, QLD
    Thanks for your help Byron I was probably being lazy by asking rather than looking but I am at work and the books are at home. I need to ring the guy and let him know so they can be done for when I get home.
    Thanks again.
  1. wtb top tailgate locking rod springs
    By hzvan in forum Archive
    Last Post: 10-10-2011, 12:16 AM
  2. springs
    By thatotherguy in forum Steering & Suspension
    Last Post: 26-09-2011, 09:23 PM
  3. leaf springs 1ton vrs standard springs hq van
    By b-rock-05 in forum The Lounge
    Last Post: 27-04-2011, 07:28 PM
  4. Replies: 7
    Last Post: 17-07-2010, 12:18 AM
