Results 1 to 9 of 9
Thread: Tidy HZ ute body
    Tidy HZ ute body
    Looks pretty clean and straight and has a 5spd cpnversion. If no-one bods it would be a great parts car or even a good ute body to use.
    http://www.ebay.com.au/itm/HOLDEN-HZ...#ht_609wt_1130
    $1000 no bids in Croyden VIC.
    Yep looks good.
    I have messages the guy to find what sort of 5 speed box is in the ute
    HZ jasmine yellow sandman van
    HX mandarin red sandman ute
    Married to Jennie285
    Looks like a Celica stick.
    does not like like a supra shifter...
    its a celica box what sort of horse power will these handle would it be ok for 350 to 400
    Cruiser jason.ruff's Avatar
    Jun 2012
    Darwin
    No they are barely able to cope with an angry 6 cylinder let alone a worked 8 cylinder. Supra box is better. Depends on how you drive too.
    the bloke im buying a supra box off suggested his research shows that SUPRA are good for 300hp.
    If driven sensibly they will be fine behind a 253 or 308. Just like an aussie 4spd, easily broken but will last if not abused.
    To use the box behind a V8 you'll need a bellhouing, clutch plate and might need a tailshaft mod, the one in this ute may have the Celica yoke with Holden uni on it but is possibly a 6cyl one. Crossmember will need modifying too as relative to the 6cyl location the box will move forward by the difference in length between a 6cyl and V8 aussie 4spd. I have a 253/308 to Celica bellhousing and clutch setup at home, but it has longer bottom bolts being a Dellow one so only really useful for HT-HJ as if you try to use it on HX or early HZ you have to wreck the rat-trap as it attaches using the lower bellhousing bolts.
  1. Tidy HJ van, probably a BO6
    Last Post: 16-04-2015, 09:16 PM
  2. Tidy HJ van
    Last Post: 09-02-2014, 09:47 PM
  3. Rather Tidy HZ Ute
    Last Post: 04-06-2013, 07:26 PM
  4. My new WB, clean and tidy.....
    By pedro82 in forum Replica Sandmans
    Last Post: 01-07-2012, 09:35 AM
  5. Tidy WB Ute
    By wbute in forum The Lounge
    Last Post: 16-11-2010, 02:21 PM
