Results 1 to 8 of 8
Thread: Power steering pumps explained
    Hi guys, i have 3 different power steering pumps
    any ideas why they differ?
    One may be the WB one which looks like a ham can and has a larger capacity and metric threads.
    One may be the earlier round shaped one.
    you got some pics adam???
    early type pump starts in ht and runs through to hz...round with neck and non metric thread..pulleys on an ht hg and early hq are different..
    wb has the ham tin look which has metric threads..
    chev looks similar to hq to wb but is different..
    ford :sick: looks like wb but sits at a wierd angle forcing you to have adjustment problems..
    Whyalla
    In the HQ series there are 3 different pumps 6cyl, V8 and 350, and there are 2 in the HZ series different part numbers but may have been updated. HJ V8 is same as HZ. HJ 6cyl same as HQ. HX uses the HJ V8 for all models
    some clarity
    HQ, HJ 6cyl
    HQ V8
    HQ 350
    HJ V8, HX all, HZ V8
    HZ 6cyl
    WB imperial mounting parts
    WB metric mounting parts (shaft retained by square section ring)
    WB metric Mounting parts (shaft retained by round section ring)
    Leroy
    i will get some photos tommorrow of stuff.
    going into shed.
    one of the ones i have is off a VL i think as its a VJ prefix 308/304, and its squarish.?
    Just to confuse things they used those pumps on heaps of agricultural equipment such as John deere round balers and some ford tractors and no doubt other applications. Must have been a generic style thing that every manufacturer used.
    Cruiser razsandman's Avatar
    Adelaide
    If you are looking to do a conversion, the coupling to the steering colounm is differant as are the lengths of the steering arms and possibly the tie rods. from non RTS to RTS and non power steer to power steer set ups. its best to buy a complete set up if you can even if you have to put a kit through the pump and replace the tie rod joints ect. im no expert or part numbers guru but ive dismantled a fair few and found these differances.
    just to add some more confusion :errf:
    1976 HJ XX7 Sandman
    Genuine VN SS manual atlas grey
    HX LE Coupe project
    raz,the steering arms are short for power steer..tie rods are all the same...
  1. Steering columns explained
    By ozbox in forum Ozbox's Workshop
    Last Post: 22-08-2020, 11:23 AM
  2. HQ HJ HX Power steering kit
    By Indy Orange in forum My Items For Sale or Buy
    Last Post: 11-05-2015, 06:52 PM
  3. power steering pumps
    By Kingsandman in forum The Lounge
    Last Post: 23-10-2014, 06:04 AM
  4. V8 Power steering
    By Doug in forum Steering & Suspension
    Last Post: 02-10-2013, 02:48 PM
  5. Adding Power Steering to a WB Ute
    By Cyclamin in forum Steering & Suspension
    Last Post: 03-09-2012, 11:42 AM
