Results 1 to 10 of 15
Thread: Speedo issue.....
    Question Speedo issue.....
    The speedo in the van has just started acting strange.
    After takeoff it flickers between 10 and 80km/h violently, then as I approach 80km/h it settles down and from then up to 100+ it behaves normally. The same thing happens as I slow down below 80km/h.
    Broken cable?
    Possibly that or oil getting up the cable. May even be as simple as the connector on the back of the speedo may not be quite straight or not attached properly. Check the cable for any kinks.
    What box?
    As above it may be a drive gear seal, kinked cable, damaged cable, melted sheath etc.
    Trimatic box. It's still doing it too.
    I hoped it would settle down and return to normal but how often does THAT happen?
    I'll check the connections on the weekend....it can't be much of a problem. Just strange.
    Sydney
    It's happened to me before Rob, a stuffed outer sheath, it must have caused the cable to wind up , and flick the speedo, as with yours, it settled down once the speed got up, I just changed the cable (after endless other things including the speedo) and it was fixed!
    Try the cable first then the rest!
    Cheers, Scotty.
    Thanks Scotty,
    Rare Spares for the cable?
    Not sure if they do cables
    OK, where then?
    2nd hand? Could be worse than mine.
    I had one made by a mob over here that makes them brand new
    Flexible drive agency is the company there is one in NSW
    hope that helps ya
    cheers gene.
  1. Tailgate issue...
    By Big Rob in forum The Lounge
    Last Post: 14-11-2014, 01:38 AM
  2. Tailgate issue
    By sandman 78 in forum The Lounge
    Last Post: 14-03-2014, 07:52 AM
  3. For Sale, HJ early and late GTS speedo, HX GTS speedo
    By Absinth in forum My Items For Sale or Buy
    Last Post: 13-10-2012, 08:41 PM
  4. Ebay issue - what do you think?
    By HZSandman in forum The Lounge
    Last Post: 24-03-2011, 05:52 AM
