Results 1 to 5 of 5
Thread: manual shifter breaking
    Guys I'm hearing that the manual shifters are very bad and tent to break. Is there anything I can do to make it stronger?
    I woudnt say that they were very bad. They get worn, most of them are 30 years old and it's a complicated linkage. If you treat it bad it gets bad but all car parts are like that. Just make sure to give yours a good overhaul.
    Ah ok. Ill give it a few extra welds before i put it in
    Cruiser Dick61's Avatar
    Sep 2012
    Warragul, Vic
    Quote Originally Posted by Matts HX View Post
    Giving it "extra welds" is not really the way to go!
    Overhaul it and make sure all the pivots are correct size and round and that all the linkages are in good order, then give it a good grease and treat it with respect. Worn pivots and linkages are common and the reason they get broken is that idiots try to force the shifter to work rather than fix them. It happens with the 4 spd floor shifter as well as the 3 spd column shifter.
    HQ Glacier White Belmont Ute
    Will do cheers mate
  1. t bar shifter problem
    By XX7SANDMN in forum Driveline
    Last Post: 19-10-2014, 05:12 PM
  2. hz steering shaft plastic plugs breaking. is it ok?
    By lcgtr1970 in forum Steering & Suspension
    Last Post: 13-04-2014, 09:36 PM
  3. 4 spd shifter rubber
    By thatotherguy in forum Interior
    Last Post: 06-01-2014, 05:02 PM
  4. Steering shaft breaking
    By Barney in forum Steering & Suspension
    Last Post: 31-05-2012, 06:36 PM
