Page 36 of 56 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 556
  1. #351
    Quote Originally Posted by Vanhayden View Post
    That is not a bad timeframe. I started 10 years ago but kind of lost the priority for a while. I am also the same with having mates in the industry but it is hard to secure their time since insurance work takes priority and its a bit cut throat these days. You need to pump out volume to earn a decent living.
    I plan to do the same as you with the rear. I will note down "vinyacote" grey as i was going to ask on here what was the paint code for the rear. Also is the rear in 2 pac without clear?
    Are you worried about the bats holding moisture?? Leading to rust.
    The back is a semi gloss lacquer, will never carry anything so im not worried about it scratching
    Im not concerned about rusting, all the seams have new seam sealer, there is rust primer and cavity wax, and heaps if it in there. New lower 1/4 panels so its pretty well water tight. Also the time I spent cleaning the underside....... it will never see rain and she sleeps in an alarmed heated garage
    Chevrolet Avalanche
    HQ Wagon
  2. #352
    P Plater Vanhayden's Avatar
    Nov 2013
    Oh ok, I wasnt thinking so much about water ingress I was more thinking along the lines of condensation. But I suppose if its in a heated garage and will never see rain, it shouldnt be a problem
    HZ Sandman 11/77 (Panama Green, DX5) Wanted QR904784
    VZ Maloo Panelvan (Black, GTO front)
  3. #353
    Heated garage that is to much grunt
  4. #354
    Heated garage!! Hey Grunt I reckon thats worth a thread on its own!
  5. #355
    The heated garage is not as scientific as that. The gargage is under the house where all the central heating ducting is located, a couple of the ducts are a bit dodgy so the esaped heat gets into the gargage.
    Certainly makes those cold winter nights a bit nicer.
    Chevrolet Avalanche
    HQ Wagon
  6. #356
    Quote Originally Posted by Grunt View Post
    wanted to get the back access panels out of the workshop so I installed them. I also stuffed polyester insulation bats into the rear access panels to cut down on road noise a bit
    Hi Grunt
    The rear is the factory colour or as close as you can get now Vinyacote grey
    Hi Grunt was wondering if you had the product / paint code that you used to paint the rear.
    Cheers.
    Gaddy.
  7. #357
    Quote Originally Posted by Gaddy View Post
    Cheers.
    Gaddy.
    no probs Gaddy, here go
    There was a problem with one tint colour but the guy knew a substitute
    Chevrolet Avalanche
    HQ Wagon
  8. #358
    We too have a heated garage and heated in the same way as grunts, we also have carpet on the floor under our yellow van. Sadly she is still rusting on the seam at the back. This will be fixed when we get the malachite van up and running. Jennie on rb iPad
    HZ jasmine yellow sandman van
    HX mandarin red sandman ute
    Married to Jennie285
  9. #359
    I think a warmer shed would cause rust to react faster than a cold shed..at the same humidity..
  10. #360
    Cruiser jason.ruff's Avatar
    Jun 2012
    Darwin
    Im in darwin so i have the opposite problem, im airconditioning my garage so i can bear to be in there this time of year. Im hoping this wont cause to much condensation if i keep it to 24 or 25 degrees.
There are currently 113 users browsing this thread. (0 members and 113 guests)
    Last Post: 07-02-2015, 11:50 AM
    Last Post: 19-10-2014, 01:03 PM
    Last Post: 30-12-2013, 06:39 PM
  5. HX sandman ute in Papaya
    Last Post: 19-03-2012, 05:27 PM
