thanks Rob, yes she will still be like new when you get her.
Its got to help compared to nothing
Chevrolet Avalanche
HQ Wagon
After the cavity wax it was time for the final assembly
All the door holes covered
other bits can now be put on like the door vents
Chevrolet Avalanche
HQ Wagon
installed the dash pad
After all the door mechanisms were grease up and working smoothly the new doors trims and hard ware were put on
Chevrolet Avalanche
HQ Wagon
Looking good. Love the colour... iwish my resto was this close!
HZ Sandman 11/77 (Panama Green, DX5) Wanted QR904784
VZ Maloo Panelvan (Black, GTO front)
Almost done.
How long has it taken you?
Chevrolet Avalanche
HQ Wagon
wanted to get the back access panels out of the workshop so I installed them. I also stuffed polyester insulation bats into the rear access panels to cut down on road noise a bit
The rear is the factory colour or as close as you can get now Vinyacote grey
Chevrolet Avalanche
HQ Wagon
That is not a bad timeframe. I started 10 years ago but kind of lost the priority for a while. I am also the same with having mates in the industry but it is hard to secure their time since insurance work takes priority and its a bit cut throat these days. You need to pump out volume to earn a decent living.
I plan to do the same as you with the rear. I will note down "vinyacote" grey as i was going to ask on here what was the paint code for the rear. Also is the rear in 2 pac without clear?
Are you worried about the batts holding moisture?? Leading to rust.
