Results 1 to 7 of 7
Thread: Hx fuel sender into 8/74 hq
    Hi guys
    just wondering if anyone knows if i can use an HX ute fuel sender in my 8/74 HQ ute?
    I ran out of fuel the other day and it took me back to my days as a 17yo driving in my HZ 253 van which drank like a bloody camel... always conking out!
    Jan 2013
    Lower blue mountains nsw
    I put the HQ fuel back into my 1971 monaro ,but installed a HZ GTS dash and the fuel gauge was going in reverse,empty to full,somewhere in the mid 70's they changed the set up, so you could have a problem
    crap. anyone know for sure?
    I'm pretty sure what I told you was correct, ie early HQ are thermal and later HQ are magnetic, and HJ-WB are magnetic. Hopefully someone here will know for certain though.
    Mr. Rare Spares
    Diamond Creek
    There are 4 different types of sender units in HX HQ models you would need to know exactly what the HX sender was in sedan, van, wagon , auto , with air and engine size then you may be able to narrow it down. The part numbers are the same for both models you just need to know what you have to see what it will fit
    Cruiser GNW1974's Avatar
    Adelaide Hills SA
    Would you have to get the sender and gauge recalibrated. A gauge works place here in Adelaide said he can refurbish the original senders and calibrate to the gauge for about the same price as buying a new sender - and his opinion was the original senders are better than the new ones.
    Nearly on the Road
    unreal. thanks guys. both are 6cyl no-frills banger well body utes. if it comes to it ill just get the HQ sender fixed. i was just wanting to use the parts ive got if possible. thanks for the imout! Ill update the thread once Ive investigated
  1. VDO oil pressure sender
    By panoz78 in forum Electrical
    Last Post: 28-02-2017, 07:25 AM
  2. Fuel Sender Units - Repo
    By hj308 in forum General Spare Parts
    Last Post: 25-06-2016, 11:24 PM
  3. Temp Sender
    By hxbunny in forum Engine
    Last Post: 08-12-2014, 06:45 PM
  4. oil gauge sender
    Last Post: 10-08-2012, 10:31 PM
  5. NOS fuel sender HJ-HZ commercial
    By HK1837 in forum Engine
    Last Post: 11-07-2012, 06:15 PM
