Results 1 to 10 of 14
Thread: Fuel Sender Units - Repo
    Just wondering if anyone reccommends replacing their fuel sender unit with the repo ones on the market, Rares etc, I think mine still works not a 100% but wondering while the tank is out if it is worthwhile?
    Speak to Greg (Ozwreck) am pretty sure he had some NOS of these or some good repro ones, he mentioned them to me a while ago, and we need an oil light sender for the red van, our fuel senders were all okay......he will know if the rares ones are okay anyways...
    Given their simplicity, I'd wonder if it's worth it as long as it's still working.
    The only one I had fault, the insulation let go and it earthed out. So I would check that at a minimum.
    Edit: As Jen just said, the one I had that was stuffed I replaced with one from Classic Oz Wreck that had been checked and was all smicko. The guy that bought the wagon off me that it was in has complained about every other little thing that died since he got it, so it much still be great, haha.
    ive sold a bunch of the repro ones coz the second hand ones are very much a hit and miss affair a lot of the time..currently i have 5 new ones in stock and have sold 5 and havent had any problems on returns..
    I need one oz how much and and how do i get hold of it, thanks
    Canberra, ACT
    If yours is a HQ B-rock-05 at some point they changed. The guage has to match the sender unit somehow. Im not sure how you even tell what is what but I think they have to be matched.
    Mauser
    Found where I read it...
    http://www.fastlane.com.au/forums/to...hq,fuel,sender
    Being that we both have vans made in '74 we should have thermal senders. My GTS guages are Flexdrive and also dated '74 so I think that means I should be ok.
    Mauser
    Quote Originally Posted by b-rock-05 View Post
    you can call me on 0249594546 in business hours and i do cards over the phone or direct deposits..$140 delivered reg and insured to where you are..
    Thanks guys ill give you a call tomorrow oz, thanks
    Leadfoot SandmanMuscle's Avatar
    Sydney
    I've got the rares one in mine now, had it for almost 2 years no dramas so far
    Feb 2016
    Ryde Sydney
    I realize it's an old thread but wanted to mention. My fuel send sender for my HZ Sandman Ute was non functional so mechanic pulled the tank out and installed a new aftermarket Fuel sender unit. On filling tank the O Ring seal supplied with aftermarket sender unit failed to seal and leaked on a full fill of the tank. Upon tank removal I checked the O Ring and it appeared slightly to big and of a very hard duro hardness, with average quality nitrile. I purchased a new replacement O Ring (part:7421765) and it was exactly the same? I am a seal guy so checked application position and size; and the correct O Ring for the job should at the very least these days be a quality Viton material, to deal with our current fuels. If anyone else does this job or is planning to do the job use P50A Viton - 49.6 x 5.7 V75. see picture below the brown one is the Viton material the black is the replacement (7421765) I was supplied.
    I'm not looking to sell them to other Sandman owners, as you should be able to get from Bearing Companies; but if you get stuck send me a message I'm happy to help.
    Geoff
  1. Hx fuel sender into 8/74 hq
    By Vombil in forum Engine
    Last Post: 28-02-2013, 01:21 AM
  2. NOS fuel sender HJ-HZ commercial
    By HK1837 in forum Engine
    Last Post: 11-07-2012, 06:15 PM
  3. Re-gasing Old Original Air-Conditioning Units HJ HX
    By Beast Master in forum Engine
    Last Post: 27-06-2012, 08:35 PM
  4. repo sales brochures
    By uterus in forum The Lounge
    Last Post: 11-01-2012, 10:15 AM
  5. Original v's N.O.S. v's Repo
    By agr071 in forum The Lounge
    Last Post: 21-03-2011, 06:16 PM
