Thread: fan fuse/wiper problem
    When I push the fan fuse in (it has to be live out of the fuse box for the moment!) it triggers the intermittent windscreen wiper to go off. anyone have any ideas where I could start looking?
    Fan works when fuse is in... wipers just wont stop! Wipers work fine through stalk switch.
    Cheers!
    Cruiser buck's Avatar
    Jan 2012
    albury / wodonga
    just had a lot of problems with this fuse myself, that fuse is wipers, washers, indicators, and heater fan, my heater wasnt working, and it turned out to be a broken wire in the loom between fuse box and fan switch after a lot of work with the multimeter. yours could be a faulty indicator stalk possibly? same thing happened to an earlier hz i had, brocken contacts it the stwich causing it to stay on, even though the twist part high beam and indicators worked perfectly.
    never late in a 5.0 litre
    Quote Originally Posted by buck View Post
    cheers Buck! Ill give the indicator stalk a shot this week. cant hurt to do the ol process of elimination
    no good. swapped a stalk out with no success... any takers??
  1. M20-M21 Selecting 1st problem
    By Calum in forum Driveline
    Last Post: 08-05-2013, 09:52 PM
  2. 308 Lifter Problem
    By chrisp in forum Engine
    Last Post: 22-03-2013, 12:13 AM
  3. Another Adjusting Problem on my WB!!!
    By 83 WB_Ute in forum Driveline
    Last Post: 22-12-2012, 10:58 AM
  4. Fuse clips?
    By GeoffroHQ in forum Electrical
    Last Post: 29-12-2011, 02:05 PM
  5. Fuse Cover Plates - We need some help!!
    By sstorana in forum The Lounge
    Last Post: 14-05-2010, 04:23 PM
