Thread: Removing fuel and brake line, plastic clips.
    Hi.
    This is one way to remove plastic clips.
    The first clip I tried to remove. Knocked the pin thru, never found it again.
    Next one, knock the pin part way out and broke the clip.
    Looked thru the tool box and found a metal dart. The type that you throw
    at a dart board.
    Place the dart over the centre of the pin and with a hammer, begin tapping
    the dart,(gently) the point of the dart will go into the plastic and then it will
    start to move the pin, so keep tapping until the pin has passed all the way thru.
    Now pin will be still attach to the dart, gently lever up clip, while still holding
    dart, once clip is free of chassis, lift up dart, clip and pin will come will it.
    Remove pin from from dart end, slide off clip and put in jar.
    I have since sharpen the point of the dart a little bit, just in case of a loose pin.
    So far so good.
    Great idea, but here is another, you get a very small drill bit and drill the centre out,not all the way through, then get a very small screw and screw it in a little till it grabs,then using a pair of pliers draw the pin out, worked for me and i reused the pins,
    Wallan, Vic
    maybe im biased but on my falcon bonnet cables (same clip) i just push it threw and buy new clips haha
    Leadfoot 1BadVan's Avatar
    WA
    wheres the fun in that....
    Quote Originally Posted by BIGCAV View Post
  1. Removing Paint From ABS Plastic...
    By 83 WB_Ute in forum Interior
    Last Post: 31-03-2015, 11:11 AM
  2. painting plastic
    By thatotherguy in forum Paint & Panel
    Last Post: 10-06-2013, 12:11 AM
  3. HQ SS - on Production line
    By GNW1974 in forum The Lounge
    Last Post: 20-08-2012, 06:06 PM
  4. Wanted: Fuel line clips
    By hxbunny in forum Archive
    Last Post: 23-02-2011, 06:28 PM
  5. Fuel and Brake Lines
    By Blocker in forum Brakes, Wheels & Tyres
    Last Post: 07-10-2010, 04:16 PM
