Results 1 to 10 of 10
Thread: Body removal, and chasis restoration.
    Dubbo
    Cool Body removal, and chasis restoration.
    Hi guys, I have finally got my van home, it only took twelve months ha ha.
    Now I have 6 weeks until the panel beater takes it off my hands to fix the body.
    Now what I want to throw out to you people.
    1. What is the easiest way to get the body off the chasis? (limited people and equipment)
    2. What should I do while the body is off?
    I am definitely no expert that is why I would like your opinions and experiences so that I can do properly. HQV6ute has seen and may help me if he can but I wanted to throw it out to everyone so I can put a to do list.
    Thanks for your help
    P.s. Sorry don't know how to do the tag thing, Myles sorry brother. :adoration:
    Black WB bodied HZ panelvan with a 400 chev called Frankie :nerviness:
    Aquarious HX windowless Kingswood project.
    Quote Originally Posted by HX76King View Post
    i know ive said it but your uncles neighbour had a fork lift a few houses up, i would definatly look into that, 100%
    ill be back in dubbo for tafe early feb i can come help if you want
    Dubbo
    Where? You have a a good eye.
    I will have to check that out. Will it fit under the roller door??
    Dubbo
    Ok now I have 3 guys depending on if he is available ;). Need a couple more.
    Where do you lift from? Planks through the front windows or under the van?
    that street we went out on, theres a bit of a workshop looking yard with a sheds, bit messy, on the same side as your uncle, yeah was only a little forklift, so should fit, ive got my ute on another chassie just to roll it, makes it alot easier, but space might be your issue
    whats the go with above beatle?? bug??, your going to want more than 4 blokes, id say atleast 6+
    Dubbo
    It took 6 blokes to lift my old tonner cab ;)
    I know the place now I think he has the "Yard Yakka" lawn mowing place ;) see how we go.
    yeah i dont know what old mate was going on about beetles, if it took 6 for the tonner your definatly going to want that forklift
    I removed the body from my chassis myself and put it back together myself. It's a bit hard to explain on here but it was pretty easy. The preparation took a while but the actual body removal took only about 30-40 minutes to get it off and the same to put it back on. The trick is to make sure you have removed everything like all front panels/motor/box/exhaust/fuel tank/brakes pipes off the master cylinder/steering column/hand brake cable at the handle etc and most importantly (and obviously) the body mounting bolts.
    If you want to know how I did it you can call me 0411075521...it's easier to describe it over the phone than write it.
    Only took two people to lift a ute body off here years ago and put it back on. Lift the body up with jacks if you don't have a fork lift. Takes time but if you are careful its pretty straight forward.
    Forklift makes it easy.
    How are you going to move it once its off?
    Yeah, should be pretty easy with a couple blokes. I'd take the rear wheels off so you can shove a plank under the chassis where the rear wheels are. Jack the whole lot up, support with planks resting on old wheels/tyres and then lower chassis from underneath. Use a dolly under the diff. You should be able to jack up the centre front of the body (with a suitable plank) and then slide another plank over the chassis/under the body and then just roll the chassis out from underneath.
  1. Tailgate glass removal
    By r0bb0 in forum Paint & Panel
    Last Post: 10-11-2014, 01:13 AM
  2. Axle removal
    By Bigtonkatoy in forum Driveline
    Last Post: 09-02-2014, 09:17 PM
  3. Ignition Removal HZ
    By hj308 in forum Electrical
    Last Post: 12-04-2013, 02:34 PM
  4. sticker removal
    By luke in forum Paint & Panel
    Last Post: 07-08-2012, 11:12 PM
  5. rust removal
    By thatotherguy in forum Paint & Panel
    Last Post: 26-02-2012, 11:13 PM
