Results 1 to 6 of 6
Thread: Air Cleaner-Duel Fuel
    Sandman Driver Rico's Avatar
    May 2011
    Benalla Victoria
    Hay all,
    My van has an Impco 300 gas mixer on it. When I bought it there was no air cleaner attached with it...was the only thing I didnt look at. Does anyone know what the heck bolts onm top of these things? I dont see a normal air cleaner fitting somehow, doubt the bonnett would bloody close.
    Thanks as always!!
    Apr 2011
    penrith
    lpg air cleaner
    I have an impco gas carby on my van I will try and get a photo of it ,see if it is the same.
    cheers
    Quote Originally Posted by Rico View Post
    Hay all,
    Thanks as always!!
    depends what base is on it..ive got an impco 425 on the sinbox with a rochester base and a 14x3inch air cleaner..had to cut the frame work one the bonnet to close it....ah wait..you have 6 cyl..dunno
    Aug 2010
    Sydney
    The Impco 300 is almost invariably used "upside down" on the end of a snorkel, which fits onto the top of a 4bbl carby.
    The frame of the 300 mixer takes a 70s Valiant filter, and it's held on by a black metal plate that fits onto the mixer itself (on the same face as the vapour line).
    If you need them, I can take some pics of my setup at present, which is how the Impco 300 was sold as a standard dual fuel package.
    what u got that on mick?
    Aug 2010
    Sydney
    Currently on the Brock wagon, while I'm waiting for a 425!
    It's got too much compression to run on fuel. The heads have had that much off them, that it's got 1/8" washers under the rocker supports, and the manifold is metal to metal on the valley ends of the block. It was all done prior to my ownership, and they're all the original parts (especially the modded intake) so I didn't want to change them. Plus it's pretty hard to find a good pair of VL heads that aren't cracked.
    A mate went through 8 heads to get 2 good ones.
  1. Air Cleaner Decal
    By GNW1974 in forum Decals by Stickthis
    Last Post: 04-02-2019, 08:38 PM
  2. Quaddie Air Cleaner
    By Taily in forum Engine
    Last Post: 31-07-2015, 11:26 PM
  3. V8 4 barrel air cleaner
    By Valencia in forum My Items For Sale or Buy
    Last Post: 11-08-2013, 12:53 PM
  4. 308 Air cleaner decals
    By locodriver2007 in forum Engine
    Last Post: 21-08-2012, 03:18 PM
  5. Air cleaner
    By jennie285 in forum Archive
    Last Post: 26-06-2010, 08:34 PM
