Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Retro-fitting Power Steering to a WB
    Sandman Driver Rico's Avatar
    May 2011
    Benalla Victoria
    Hay guys,
    Want to retro fit power steering to my WB, have seen an old blokes WB ute with a VP Commodre pump etc on it. Can anyone tell me whats involved here? what would I need (besides the obvious-power steer pump ) just want to make it a bit easier to
    Thanks!
    just save yourself the agro and buy a correct 6 cyl kit with the right brackets and bolts,spacers and pulley..i sell them for $550 when i have them..you need any hq to wb power steering box with coupling and pitman arm..if you can find a 6 cyl vb vc vh commodore then you get the pump and brackets,bolts and crank pulley from them..there is 2 types of high pressure hoses but you can buy these new..commodore one will not fit..
    Do you really need it with a 6 cylinder?
    Engine makes no difference to how hard it is to steer. Sports wheel and wider tyres have 5 x as much affect. I put power steer on a 6cyl WB tonner once and it made it a pleasure to drive.
    Given the state of the exterior of your van, I'd first start with looking at lubricating and replacing your steering components were required.
    Also, id check you have the longer manual steering arms. As Byron said, sports wheels also add to the problem.
    I think people forget that we survived years without power steering, it's not an essential. Plus you learn not to scrub tyres in car parks without it.
    Cruiser Mazdragon's Avatar
    I have power steer on Mr Beigy... he was a 6 cyl. before, now an 8 and I wouldn't be w/out it. It does make it a lot easier to drive... i've driven 8's w/out and found them heavier... and yes, your wheels can make a huge diff too. There's a complete system for sale on Gumtree: http://vic.gumtree.com.au/c-Cars-Veh...AdIdZ311022780, however, it is for a v8 which I know they're slight different, but thought i'd put it up here anyway in case anybody else is interested.
    it's here and I love it!!
    Its not the wheels, its the width of the tyres. Also tread depth, wheel alignment and air pressure.
    I replaced 215/14" standard wheels with 225/15" Simmons, had a wheel alignment and it was lighter in the steering.
    My old HX ute here with 215/14 tyres on jelly bean rims and a 6 cylinder is lighter than my current WB with a 253 and power steering running 235/14.
    Apr 2011
    penrith
    power steering
    Hi there,I have a hx van the best thing i ever did was put power steering on it,it gets driven most days now i can park it .the only thing i would do different is leave the long steering arms on and not fit the short ones.
    cheers.
    Leadfoot 0488TINTER's Avatar
    Wetherill Park NSW
    as long as you dont mind getting anally raped you could go this way
    http://www.blacksracks.com.au/
    Cruiser TwoTees's Avatar
    Canberra
    Rico
    Here you go. Currently at $20 but expect to pay more....
    http://www.ebay.com.au/itm/HOLDEN-6-...#ht_500wt_1156
  1. HQ HJ HX Power steering kit
    By Indy Orange in forum My Items For Sale or Buy
    Last Post: 11-05-2015, 06:52 PM
  2. power steering pumps
    By Kingsandman in forum The Lounge
    Last Post: 23-10-2014, 06:04 AM
  3. V8 Power steering
    By Doug in forum Steering & Suspension
    Last Post: 02-10-2013, 02:48 PM
  4. Adding Power Steering to a WB Ute
    By Cyclamin in forum Steering & Suspension
    Last Post: 03-09-2012, 11:42 AM
  5. Power steering - details
    By Blocker in forum Steering & Suspension
    Last Post: 22-10-2011, 09:05 PM
