Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: hz wiper motor
    P Plater hzvan's Avatar
    canberra
    hz wiper motor
    I am having abit of trouble with my wiper motor
    it does not work at all
    i have checked it has earth and one of the 4 wires going in has 12 volts to it
    but can not work it out
    any help would be good
    thanks steve
    steve..the hq to wb series of wiper motors are the biggest pos since the eh wiper motor..problem is they are in a position that allows them to get wet and the water goes inside to the bottom where the bearing is and they seize..another problem is that because they dont get used they seize as well..
    a tip for all is to use your wiper motor on a regular basis wether its raining or not..especially run them after washing the car.
    if you are in need of a second hand one i sell good tested working for $95 or rebuilt for $195..usually this is on an exchange basis but for mysandman humans i will do them outright no exchange at this price.
    canberra
    Thankyou for that info and your prices
    I know were to get one if the one i found today in the shed stops
    The motor that would not work was a lucas, that looked in good condition
    On the out side but it got the better of me and i pulled it a part
    All the copper wire is burnt out and there was a little copper arm broken of under
    The plastic gear
    I had a preslite one that i put on and worked but stops were ever when turned off
    As i have not driven van in 8 years i cant remember if the wipers should return to bottom of windscreen
    Could someone please give me a yes or no on that
    Thankyou
    Steve
    Yep, return to bottom.
    canberra
    so what can i do to the motor to get them to return to the bottom of the screen when turned of?
    Have you got the earth stap from the motor body to the fire wall .the return home relies on contacts to the under side of the large cog .I do think the motor would work because it gets it earth via the switching. therefore if the motor is not earthed the return home can not work .that's my take anyway.
    Rod is correct. The earth strap is the key.
    canberra
    I forgot to connect earth strap
    But now it keeps blowing fueses
    earth strap is not only bit that makes it park..
    Quote Originally Posted by hzvan View Post
    Been there done that ok I think there is an short in the motor somewhere ,get another motor or leave the earth strap of and manually try to turn wiper of so they park home oz sell reco ones with concrete warranty .
  1. Wiper dwell
    By L31 Sandman in forum The Lounge
    Last Post: 28-02-2017, 07:55 PM
  2. WTB - HJ X Z wiper arm pivots
    By GTS in forum My Items For Sale or Buy
    Last Post: 29-08-2013, 03:24 PM
  3. Wiper Arm question
    By GTS in forum Electrical
    Last Post: 10-08-2011, 11:26 AM
  4. Lucas Wiper Motor
    By GNW1974 in forum Electrical
    Last Post: 02-06-2011, 04:15 PM
  5. WTB - HJ wiper motor
    By GTS in forum Archive
    Last Post: 14-01-2011, 08:17 PM
