If you do go ahead with the rebuild yourself you may find some of the pictures here
http://gallery.oldholden.com/HQ_SS/T...s/Aussie+4spd/
of some use.
Another trick on the aussie box's is the R+ R of the rear extension housing.
Here is what I jotted down for someone else a while ago.
When you go to take the rear housing off loosen the bolt that holds the reverse light switch and detent ball and spring.
Loosen the bolt enough to move the switch away from the reverse gear leaver but not right out.
Then loosen the reverse gear lock nut but not off leave it on a few threads at least, then tap the center pin down with a hammer.
The reason for doing this is that it lowers the reverse gear pivot in side the gearbox.
Now remove all the bolts that hold the rear housing on and pull it backwards off the main housing.
You may have to give it a tap to dislodge it from the locating dowels.
Now if you pull it back and down it may pull the reverse gear back on the main shaft a bit which is good, as it will give you a bit more room to disengage the reverse gear from the pivot arm.
Then rear housing should come off (you may have to twist it a little bit to one side still to disengage it)
If you put a little bit of grease on the new gasket when you go to put it back on it will hold it in place on the main housing.
Now the other pictures are to do with the thrust washers on the reverse idler gear.
These tend to move or fall off the reverse idle shaft when you disassemble the rear housing.
If you have a look at the pictures it shows what you need to do with them before reassembly if you do not locate them corectly they will bind up the reverse gear idler
and make it hard to turn the box from the input shaft when not in gear and will end up with them spinning in the box and damaging the housing.
To refit the rear housing on to the case it is a mater of locating the reverse gear pivot in to reverse gear then pushing the housing forward and
then locate the reverse gear idler in to the thrust washer then the back housing of the box.
Then locate on the dowels, fit a couple of bolts in to the housing and lightly tighten up.
If it gets harder to turn the input shaft when you have tightened it up it may of moved on the thrust washers.
Now tighten up the reverse gear pivot nut and try the operation of the reverse gear mechanism to make sure it is all working ok.
The pictures numbered 001 to 008 on the above link are to do with this text.
Also other than HK 1837's way of doing the layshaft bearings is that you can get them all to stay in place if you use Vaseline on the inside of the gear and also on the
rollers themselves.
You can also use it to hold the layshaft thrust washers in place when you put the gear back into the box.
Grease does the same thing but the vaso melts out real fast once the box warms up and lets the oil in to lube everything up quicker.
Just do not give it a hard time until it has had time for the oil to work its way in.
Cheers Paul.
