Results 1 to 6 of 6
Thread: What model doors will fit the HX?
    Will HQ thru to WB front left hand doors from these cars fit the HX?Or are they different?
    Cheers Kiwivan
    There are a few threads on here already about this. HQ have the little triangle bit at the top corner. There are some differences between the internal pressings relating to ash trays in sedans etc. Commercial vehicles did not have side intrusion bars in Australia due to ADR's so may be the same in NZ. Otherwise they will all fit but depends on how accurate you want your van. WB had different outer door handles.
    I reckon the rust free door you find is the best one to fit personally. If someone pulls your door trims off and sees side intrusion bars then they have too much time on their hands.
    As above, all fit. Other main differences apart from those mentioned already are holes for side strips on Kingswood upwards (HQ different to HJ/X, HZ different, WB different) mirror holes (remote HQ-HZ, WB etc all different), nipples for stainless on door line on Premier/Statesman. As WBute says, all this is easier to fix than rust!
    I have checked the other threads and knew about the triangle,But there seems to be a lot more HQ doors about.I will go the rust free path.I just needed conformation before I purchased.
    Cheers Kiwivan
    One of the doors on our yellow van is HQ, you would never know, we just scewed out the bit in the corner, and drilled new holes for the window guides to hold the bailey chanel, and yes easier with a rust free HQ door than trying to fix original rusty one...
  1. HQ front doors VIC
    By Vombil in forum Vehicles or Items Found for Sale
    Last Post: 06-05-2015, 02:17 AM
  2. FX / FJ doors
    By Wally in forum My Items For Sale or Buy
    Last Post: 22-01-2014, 09:59 PM
  3. HJ X Z doors
    By locodriver2007 in forum Archive
    Last Post: 26-07-2012, 06:39 PM
  4. HJ van trim above doors.. ???
    By HJ XX7 in forum Paint & Panel
    Last Post: 12-12-2011, 08:35 PM
