Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: Help Required
  1. #21
    No way to tell from a chassis number unless you can find the details of it on the micro fiche from Holden... good luck with that....
    It is looking more like a Sandman than not but I would like to see a pic of the body plate to see what the trim and paint codes are.
    I would say it probably is a Sandman and if you restored it as one then no one can really say it isn't one as it has all the Sandman identifiers, it would still be worth around $25000 to $30000 fully restored.
  2. #22
    Will get a pic on here of the body plate, in regards to picking up a second hand bracket I think that would be pretty difficult as people dont seem to be wrecking any vans but wanting silly prices for so called easy restorations but will keep my eye out, I actually went into my local holden dealer yesterday to pick their brain but they werent able to shed any further light on it, on the bright side they did let me borrow their 5-6 inch thick manual on the HJ holden series, I tried to locate the bracket in question as an item number but the book does not show the bracket in any detail what so ever that I could see. Do you think a metal fabricator could pretty much replicate the original item from photos.
  3. #23
    Give Greg a call at Classic Oz Wreck, he is wrecking the HJ Sandman pictured below and it probably still has the rear hoodlining bracket on it.
    http://www.classicozwreck.com.au/contact_us_5.html
  4. #24
    Classic oZ wreck
    I wonder why he is wrecking that????
  5. #25
    Rang them this morning too late they had already cut out the whole top arch section the bracket is attached to and sold to some guy for $350? Thanks for tip anyway.:frown:
  6. #26
    [IMG][/IMG]
  7. #27
    Thumbs up
    Looking at the body plate and with your other information I'd say there is a 90% certainty it is a genuine Sandy man......
  8. #28
    Interesting body plate. That one is stamped while all the others that I seem to recall (short memory) were reverse stamped.
    Are these common?
  9. #29
    Are these common?
    It is common in Adelaide built cars and bodies up until late HJ.... seems to have changed to reversed stamped from around 1-76 onwards.
  10. #30
    looks like the 7 on the WM70 has been tampered with, and it was a 6 (1 tonner WM 60 )
  1. Hx panelvan help required
    By theoriginalrat1 in forum HX Sandman
    Last Post: 17-05-2015, 12:10 AM
  2. HX Heater help required
    By Davestown in forum Engine
    Last Post: 15-04-2015, 08:50 PM
  3. Paint required
    By HZSandman in forum Paint & Panel
    Last Post: 28-10-2011, 08:18 PM
  4. Tyre and rim help required
    By HZSandman in forum Brakes, Wheels & Tyres
    Last Post: 10-09-2011, 07:34 PM
  5. HJ Top tailgate info required please
    By GTS in forum Paint & Panel
    Last Post: 12-01-2011, 07:28 AM
